unable to add/assign circuit to a MCB electrical distribution panel
heichan88
heichan88
I have some MCB electrical distribution panel rfa, but unable to assign/add circuit to it, nor no distribution system can be matched even there are 220/380 is set in MEP settings.
please see attachment. My area is in Hongkong (220/380) Please advie, thanks
fabiosato
Open the family and select the electrical connector, youn can change the value of the voltage parameter, my suggestion is to link a parameter, so you can change it in the project environment.
Fábio Sato
heichan88
Dear Fabiosato,
I tried modifying voltage to 220/380V following your comment,  but seems still the same. I want to add one 120V receptacle circuit and one 220 lighting circuit to this MCB, please see attached RVT.
Thanks!
KooimanBIM
What component you want to connect to this panel? And does it gives a warning if you try to connect something?
Maybe you have to change the number of poles to "3".
heichan88
@fabiosato @KooimanBIM done, thanks!
