Two parallel pumps
Two parallel pumps
tuuletin
Two parallel pumps
tuuletin
does anybody know, how to set the portion of the total flow to a certain pump in parallel?
I found this picture from Getting into the Flow: Understanding Connectors in Revit.
eric_grey
Hello Tuuletin,
You will need to edit the connectors in the family.  Change the Flow Configuration to System, then set the Flow Factor.  To apply different values to different families, you will either need to create separate families for different factors or map those parameters to new instance parameters in the family.  I suggest the mapping option so you can use the same family for both.
Hope that helps,
Eric
Eric Grey
Software QA Analyst
tuuletin
Thanks for the quick reply!
