Two items with the same mark
mwoodsonUUZVA
Message 1 of 12
mwoodsonUUZVA
My Project Manager wants two different items to have the same mark. Is there a way for me to schedule these items without "itemizing every instance"?
Replies (11)
Message 2 of 12
RobDraw
Based on the limited criteria, the answer is yes. That's the easy part. Your requirements for the rest of the schedule will determine if you can get what you want.
Rob
Message 3 of 12
mwoodsonUUZVA
That's what I figured. Back to the drawing board! Thanks for responding.
Message 4 of 12
Of course.  Sort your schedule by another field instead of Mark.  Also, you might want to look into Type Mark.
Message 5 of 12
mwoodsonUUZVA
I will try sorting by another parameter. That actually makes the most sense, thank you!
Message 6 of 12
RobDraw
You're welcome.
Rob
Message 7 of 12
RobDraw
If you're already sorting by Mark and this is the first time you're dealing with duplicate marks, what difference does it make if you itemize every instance?
Rob
Message 8 of 12
mwoodsonUUZVA
I have duplicate marks but they're all the same piece of equipment. Example: Item 120 is wire shelving, and I have about 50 in my model. Item 313 is a combi oven and a water filter. If I itemize my schedule, all 50 wire shelves will show up, and I don't want that. The problem I'm having is the quantity is counting both instances of the mark. I am having a hard time explaining this, and I apologize if this is confusing.
Message 9 of 12
RobDraw
Okay, I get it now.
Maybe you should make both items into one so that you can schedule them as a single line item.
Rob
Message 10 of 12
RobDraw
You would be better off using the type mark for equipment. The mark value is an instance parameter.
Rob
Message 11 of 12
iainsavage
That is the perfect example of when to use Type Mark instead of Mark.
I don't think your project manager understands what they are asking for here and maybe this is an opportunity for you to educate them.
Although it can be ignored there's probably a very good reason why Revit warns you every time that you create items with duplicate Mark values
Message 12 of 12
HVAC-Novice
it is really bad practice to use the same mark for 2 items. Especially if it is the same type of item and in the same schedule.
Mark would be used if you need to identify each specific item. Like there is a difference and they are not exchangeable. In your case of shelves, I assume all shelves of the same size and type are the same and could swapped around, type-mark seems more appropriate.
One example, for regulars isolation valves I use type-mark, since each 2"valve is the same and they could be swapped. For control valves, I use mark, since a controls contractor needs to address each individually and even if they are the very same type of control valve, are unique.
So if each shelf has a specific color, and needs to be a ta specific location, use mark and distinct names. If they are all the same, use type-mark.
Revit Version: R2026.2
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
