Tracking PANEL schedules across multiple models
Ozzyflorespro
Ozzyflorespro
Good morning Autodesk Users,
*Im reposting this question with slight edits*
We have a campus with multiple buildings. Each building has its own Revit model and we want to track the Electrical Load (panel Schedules) across all these models at once. Is this possible?
hmunsell
Make a Coordination Model and load the buildings into it. Then you should be able to make Schedules, using the "Include Elements in Links" option, and then filter them by building.
Howard Munsell
iainsavage
Two possibilities come to mind.
  1. Link each separate building model into an overall site plan model. Create schedules in that model and in the schedules check the "Include elements in links" option.
  2. Export the schedules and then amalgamate them outside of Revit in a spreadsheet app.
Ozzyflorespro
Hey! Thank you so much for the quick response. I will be testing out this process in a few days.. trying to finish other submissions but this sounds like what I was thinking but wanted confirmation. Thank you very much! I will follow up
Ozzyflorespro
Hey Thank you so much for the quick response. I will be testing this out in a few days and will let you know! Thank you again!!
Ozzyflorespro
Hey! I updated the thread/question. Let me know if you have answer. thank you very much!
