the gap in the existing duct after the installation a new balancing damper
aleksandr_makarovPBGMB
Observer Observer
Observer
Observer
Hello everyone, can you please help to remove the gap in the existing duct after the installation of a new balancing damper? I am doing a renovation project and there is existing ductwork. When I installed new balancing dampers and printed drawings for the phase filter (Show Previous + Demo) there were gaps for new balancing dampers.
HVAC-Novice
If this is demolition in "new phase", this may be an issue with visibility since the new dampers are NEW
check phase filter of the view.
Just guessing since your view is called demolition. Demolition normally wouldn't show the new items.
if you want to show demo, you also should verify how you show items to be demo'd. if you insert a damper, you technically demo that little piece of duct that gets cut out.
Revit Version: R2026.5
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
Observer
Observer
I am not showing demolished elements for new construction drawings (only existing and new).
Please see the settings for Phase Filters in the attached picture.
I understand that the new damper is removing the existing peace of duct.
But maybe there is a way how to show existing ductwork without these gaps?
Observer
Observer
Probably the solution is to show the removed by the new balancing damper piece of ductwork as a demolished duct. But I don't understand how to do it automatically.
HVAC-Novice
It depends on what you want to show on a specific view.
what I do is:
- demo view: shows existing - demo and demo is dashed/colored or some other scheme. Doe snot show NEW items
- construction: shows existing and NEW
it looks like you set it up as a demo view, but want to show new items.
Observer
Observer
For new construction drawings, there is no issue. There are existing and new ducts and elements. For demolition drawings, I am showing existing and demolished ducts and elements and everything looks good, except these disappeared pieces of duct where new balancing dampers are installed (which should be shown as demolished duct automatically).
iainsavage
Think about what happens in reality.
You have existing duct.
You want to insert a damper.
You need to cut out a section of existing duct - Revit would class this as "demolition".
So after you insert the damper you need to recreate the missing short section of existing duct which is to be removed and demolish it in your construction phase.
