The angular in family environment is very tricky
Crystal_Duck
Crystal_Duck
Hi. Im assigning an angular parameter to current family. Everything works fine except for the last one.
The behaviour is quite confusing. Im not sure this is a revit bug or not.
Please take a look at the short video below
Does anyone else encounter this problem?
Any help would be appreciated.
fabiosato
I suggest you create a reference line to be controlled by the angle parameter, and the solid be created using this reference line as work plane
Fábio Sato
Crystal_Duck
Hi, @fabiosato
The family is a faced base type, so I think Ref-plane is the good choice in this case
If you can take a look, I will attach the family here
fabiosato
Please share the family for testing.
Fábio Sato
