Tee not appearing
Tee not appearing
tmccar
Advisor Advisor
Message 1 of 19
Tee not appearing
tmccar
When I run some PVC pipework, the tees are not forming as normal. Elbows are ok, but tee connections are just showing as  direct connections. Is there a setting for this?
Replies (18)
Message 2 of 19
RobDraw
Routing preferences
Rob
Message 3 of 19
tmccar
What setting should I change in Routing Preferences? "Tee" is set to "all"
Message 4 of 19
RobDraw
All? Really? I think you think that it means something that it doesn't.
Look at the headers and, in the appropriate column, select the tee that should be used.
Rob
Message 5 of 19
tmccar
Sorry - I should have said "Preferred Junction Type" says "Tee" Min Size - All
Message 6 of 19
iainsavage
Could you post a screenshot of your routing preferences and maybe a screenshot of what you’re seeing in the model?
Message 7 of 19
RobDraw
I knew what you were talking about.
Did you find the correct column for setting which tee you want?
Do you have any tees in the model?
Rob
Message 8 of 19
tmccar
This is what I'm seeing:
Message 9 of 19
RobDraw
Sorry for the misunderstanding.
Your preferred junction type is a tee and that's for all sizes.
Your junction, in the "line" below has size constraints, both min and max. If your pipes are outside of that range, you will need to expand that range or add the appropriate tee and set the size constraints appropriately.
Rob
Message 10 of 19
tmccar
It's happening for all sizes
Message 11 of 19
Try to load another PVC Tee fitting family in set the below to All.
Message 12 of 19
RobDraw
You're gonna have to share your model or a small portion that exhibits the behavior, to end the guessing.
Have you tried removing the size constraints on the tee that you have specified?
Rob
Message 13 of 19
tmccar
Yes, I did that
Message 14 of 19
RobDraw
If you can share the model, that would end all doubt.
My next guess is that the family that you have specified is not working for some reason.
Rob
Message 15 of 19
tmccar
Here is the model:
Message 16 of 19
RobDraw
Sorry, I don't have 2022 loaded. I might be able to get to it after work if no one else figures it out in the mean time.
Rob
Message 17 of 19
tmccar
Ok, thanks.
If I open the file on my PC at home, it works OK so it's so kind of universal setting.
Message 18 of 19
RobDraw
There's no "universal" setting within Revit that would effect that.
Rob
Message 19 of 19
tmccar
I sent this to Autodesk Support as a support case. It's now working.
