Tags
Tags
rraghavendraTT3JQ
Tags
rraghavendraTT3JQ
I want to include the total length, including insets, in the tag, but the labels currently only display the length parameter. I couldn't find any parameters that incorporate the insets. Could someone guide me on how to include the insets values as well?
robert2JCCH
I don't work in the MEP Fabrication sphere so my knowledge is limited on the topic.
MEP fabrication sort of groups multiple design categories (Duct, Fitting, Accessory) all into one blanket Tag category. As part of that you're likely going to lose some baseline labelling since the list of parameters will become generalized.
I see that you can add Shared Parameters into the label family. First question - is the Inset in the fire damper a Shared Parameter?
If it isn't you'll have to figure out how to push the Inset data from the fabrication part into the Shared Parameter you're using to label the Inset.
rraghavendraTT3JQ
Hello Robert,
the insets value is not a shared parameter so I wanted to know how do we push this fabrication part data as a shared parameter.
