Tagging the length between taps and taps and pipe ends?
i_am_fail
i_am_fail
When tagging a pipe with tap(s) on them, how can I tag the lengths between taps and between taps and the pipe ends?
I'm using Revit 2018
L.Maas
You can not. Tags pull information from parameters in the families. As there is no information available in the parameters regarding the distance between valves or valves and end of pipe this can no be tagged. Dimensioning seems to be the most straightforward way to obtain this information
Louis
Please mention Revit version, especially when uploading Revit files.
i_am_fail
Thank you, unfortunately dimensions can't tag the cut length (fitting takeouts subtracted) between the fittings at the end of pipes and the outlets, so it's not possible to feasibly create piping plans for code review in Revit software, it would all have to be painstakingly done by hand one custom length tag at a time.
fabiosato
I am not sure if the following suggestion is what you want, each pipe branch is assigned to a section value, if you create a schedule and sort the pipes per section, then you can get the total length for each section.
Fábio Sato
i_am_fail
The problem is this:
When looking at a network of pipes, it's important for many reasons to know the distance between each junction, regardless whether or not it is a tap or a tee junction.
Revit allows dimensioning/tagging and scheduling the length for junctions that use a tee, because it splits the pipe.
However, it has to be done manually to do the same thing for taps, because they do not break the pipe, and the pipe knows nothing about the length from a pipe beginning to a tap.
The way other MEP software handles this problem is to make outlets part of the pipe 'family', each tap or outlet makes a pipe segment with taps on it as a family component, then the taps have parameters like offset from one end of a pipe, and rotation angle, which can be modified later.
Most importantly, it allows creating tags all at once which show the offset length from all outlets on a pipe segment. In plan views, this is critical information for all kinds of things down the road.
In revit, pipe taps are free floating objects and very poorly implemented. In order to get the correct functionality, an API solution would have to be developed that iterated over all pipe taps and pipe segments, found interfering pipe IDs with tap ID's, did some geometry functions to figure out the offsets, and finally some functions to add the dimensions or tags.
Taps, as far as I know, are not frequently used for many trades (such as plumbing), but they are with fire protection, because we can have dozens of sprinklers or branch lines coming off a pipe segment. Using tees for this results in buying tons of fittings, when you can do it for a fraction of the price using welded taps/outlets. When you have hundreds of sprinklers and dozens of branch lines on a project, you can easily see how you would have to manually add hundreds if not thousands of manual dimensions just to make a drawing usable in Revit.
Do you guys know how to reduce the denominator of the the pipe sloping fraction from 1/256 to at least something more manageable like a 1/8th of an inch??
