Announcements
Tagging in Revit
Tagging in Revit
Couple of questions with tagging fabrication parts in Revit:
1) Can you export tags from CADmep to Revit?
If not:
2) Can you make the border oval instead of a box?
3) How can I change the size tag from 600mmX400mm to 600x400 for fabrication parts (I've tried "Size" "Free Size" "Overall Size" and "Size of Connector End"
NimeshJ
Hello @Anonymous ,
1. I don't know if we can export tags from CADmep to Revit.
2. Border cannot be edited but I have a solution for same.
You can place lines inside tag around tag as shown below.
Line BorderLine Border
3. Simple solution, go to project units -> HVAC/Piping (whichever you are trying to control) -> Duct/Pipe Size -> Unit Symbol -> None.
Check below attached image for same.
