Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Tagging in Revit
Tagging in Revit
Couple of questions with tagging fabrication parts in Revit:
1) Can you export tags from CADmep to Revit?
If not:
2) Can you make the border oval instead of a box?
3) How can I change the size tag from 600mmX400mm to 600x400 for fabrication parts (I've tried "Size" "Free Size" "Overall Size" and "Size of Connector End"
NimeshJ
Hello @Anonymous ,
1. I don't know if we can export tags from CADmep to Revit.
2. Border cannot be edited but I have a solution for same.
You can place lines inside tag around tag as shown below.
Line BorderLine Border
3. Simple solution, go to project units -> HVAC/Piping (whichever you are trying to control) -> Duct/Pipe Size -> Unit Symbol -> None.
Check below attached image for same.
