Tag queries
Tag queries
Right now I am working on a project and a part of the project which is a mechanical room has done by another company in AutoCAD Plant so I used the same 3D model and imported to my revit project. Now I have a question about tagging, I would like to tag the pipes in mechanical room with the name of the layer that they made in AutoCAD Plant.
I need to know thet is there any way to use tagging in revit and tag the imported file? or tagging by using the query information(specificaly layer name)?
hakanern
Hi, moezzi614
You can't tag the autocad file transferred to revit
When you Bind in revit, each pipe expresses a pointless line.
You can follow autocad file to create a new model.
