Revit MEP Forum
Spot Elevation Disappears When I Change the Detail Level
2 REPLIES 2
louis8BAFQ
302 Views, 2 Replies
I am able to place spot elevations on these pipes while in the fine detail level, but when I switch to coarse detail, some but not all of the spot elevations disappear. Any idea what might be causing this? I've tried expanding the view range as far as I could but that did not work.
2 REPLIES 2
RobDraw
in reply to: louis8BAFQ
Maybe it's not hosted in quite the same way as the ones that stay?
What happens without the leader, and attached vs. loose with the leader?
Rob
hmunsell
you pipe appears to have insulation on it... you could be tagging the insulation vs the Pipe, which despairs when you change the detail level.
The 9' elevation is selecting the Insulation, The 9'-3" is selecting the pipe.
Howard Munsell
