I am able to place spot elevations on these pipes while in the fine detail level, but when I switch to coarse detail, some but not all of the spot elevations disappear. Any idea what might be causing this? I've tried expanding the view range as far as I could but that did not work.
Solved by hmunsell. Go to Solution.
Maybe it's not hosted in quite the same way as the ones that stay?
What happens without the leader, and attached vs. loose with the leader?
you pipe appears to have insulation on it... you could be tagging the insulation vs the Pipe, which despairs when you change the detail level.
The 9' elevation is selecting the Insulation, The 9'-3" is selecting the pipe.
Howard Munsell
