Space/Zone Design Conditions Color Scheme
giafil007
giafil007
I'm trying to create a color scheme to display the design conditions for a space (eg. temperature, relative humidity) but I can't seem to find a way to specify them. I tried to bypass the problem by typing the conditions on the comments field on the zone each space belongs to but I can't select this parameter when creating a scheme. Is there a way to achieve the desired effect? I have already made a scheme based on the zone names but different zones may have the same design conditions and I would like to display that information in a separate view.
iainsavage
You can use the setpoints in a zone colour scheme:
The setpoints don't appear in a Space colour scheme because, I suspect, the setpoints are not assigned directly to the Spaces they are assigned to the Space Type (which can be used in the colour scheme).
You can however create your own shared parameter and assign it Spaces then populate values for that - it would involve duplicating the setpoints in the Space Type and re-typing them for individual Spaces.
Or you could just use the Space Type parameter and then have a key which states the setpoints for each Space Type.
