something on my sheet family is not showing up on 2 of my sheets
jakeQTGYV
jakeQTGYV
part of the logo on my sheet family is not showing up on 2 of my sheets. but it is showing up on 2 of them.
RobDraw
Can you share/illustrate an example?
Rob
Delete the title block from the two sheets, copy paste aligned the title block from a correct sheet to those two sheets.
iainsavage
Do you maybe have two different versions of your titleblock family loaded in the project?
@ToanDN 's suggestion should correct your immediate problem but it might recur if you are selecting the wrong version for new sheets.
jakeQTGYV
The image you attached accurately demonstrates my problem. But, unfortunately no, even if I delete the title block not showing part of the logo, off of the sheet, copy it from another sheet where its showing up and then paste it to the sheet, it still will not show.
jakeQTGYV
I figured it out, it was my imported category's in the VG of the sheet being checked off.
