Showing objects/tags/model outside view range?
OK. I've been having issue after issue with Revit since I've started using it but this one was the one that finally broke me.
This issue has to do with showing what I believe to be too wide of a range of objects on the same plan.
Lighting and power are easy enough however low voltage seems to be my sticking point.
This is an issue across both Revit 2020 and Revit 2021. If there is a specific solution for one version versus the other that will still be helpful to know.
Typically for our low voltage plans we want to show the ceiling grid, the room tags, ceiling mounted items, wall mounted items, and floor mounted items. E.g. wireless access points, data jacks, and data floor boxes.
For the hours I've spent trying to get all of them to show I always seem to be missing one of them in some form or fashion.
I've attached a pair of sample files that hopefully show what I am talking about.
We are don't working with our own architectural revit file instead linking whatever file we get from the architect so changes to that won't work for a solution. I tried to replicate that with the arch and elec models attached.
If there is a solution for either a reflected ceiling plan or a floor plan doesn't really matter so long as all the elements will be visible. In this sample I has a wireless access point, and single data jack, and a floor box all shown. I am hoping that general solution that can be applied to a range of jobs that we work can be found. The typical issues that I have encountered are the room/space tag not showing, the ceiling grid not showing, or the floor items not showing.
One possible note that may or may not impact a solution. Currently the way I am getting floor boxes to show is by creating a filter. Because they are something that we want on both power and on low voltage. So we created the family as a power family and then I am using a filter to show it on low voltage. If there is another way to handle this as well that would be great. We don't want to show the general receptacles just the floor boxes that will have data jacks inside them.
Let me know if I need to clarify or provide more information to help with an answer. If this is impossible to do an explanation as to why would be helpful.
(I miss autocad layers for this.)
