Show level for pipe, duct, and conduits on schedles
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Not a question, but I wanted to respond to an idea request. Except I can't attach images there, so I started a new thread.
Original comment by Sujanc;
We can't distinguish the pipe, duct & conduit level wise in schedule for a high rise building. It will be very much helpful if we get an option in schedule to segregate the items by their reference level."
My response:
This is actually possible if you feel like trying a macro, and you can add a project parameter. Here are the steps:
1. Start the macro manager (you may have to check your security settings.)
2. In the Macro Manager (MM) window, hit the "Create Module" button.
3. Name the module "SetMEPElevations". (Spelling and keeping capitalization the same is critical - C# is case sensitive, and close doesn't cut it. You can also change the naming later once you get it working, if you want to.)
4. Make sure the language is "C#" and select OK.
5. A code window will open up. Delete the contents and paste the following in the window:
* Created by SharpDevelop.
* To change this template use Tools | Options | Coding | Edit Standard Headers.
using System;
using Autodesk.Revit.UI;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI.Selection;
using System.Collections.Generic;
using System.Linq;
using Autodesk.Revit.DB.Electrical;
using Autodesk.Revit.DB.Mechanical;
using Autodesk.Revit.DB.Plumbing;
namespace SetMEPElevations
[Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)]
[Autodesk.Revit.DB.Macros.AddInId("1B655761-F700-49B1-9AB4-4036C5BA5C83")]
public partial class ThisApplication
private void Module_Startup(object sender, EventArgs e)
private void Module_Shutdown(object sender, EventArgs e)
#region Revit Macros generated code
private void InternalStartup()
this.Startup += new System.EventHandler(Module_Startup);
this.Shutdown += new System.EventHandler(Module_Shutdown);
#endregion
public void SetMEPElevationsMacro()
//Get references to revit and the current open file
UIDocument uidoc = this.ActiveUIDocument;
Document doc = this.ActiveUIDocument.Document;
int n = 0;
//get all the conduits
ElementClassFilter conduitFilter = new ElementClassFilter(typeof(Conduit));
ElementCategoryFilter conduitCategoryfilter = new ElementCategoryFilter(BuiltInCategory.OST_Conduit);
LogicalAndFilter conduitInstancesFilter = new LogicalAndFilter(conduitFilter, conduitCategoryfilter);
//get all the pipes
ElementClassFilter ductFilter = new ElementClassFilter(typeof(Pipe));
ElementCategoryFilter pipeCategoryfilter = new ElementCategoryFilter(BuiltInCategory.OST_PipeCurves);
LogicalAndFilter pipeInstancesFilter = new LogicalAndFilter(ductFilter, pipeCategoryfilter);
//get all the ducts
ElementClassFilter pipeFilter = new ElementClassFilter(typeof(Duct));
ElementCategoryFilter ductCategoryfilter = new ElementCategoryFilter(BuiltInCategory.OST_DuctCurves);
LogicalAndFilter ductInstancesFilter = new LogicalAndFilter(pipeFilter, ductCategoryfilter);
//Combine the three filters
LogicalOrFilter conduitsandPipesFilter = new LogicalOrFilter (conduitInstancesFilter, pipeInstancesFilter);
LogicalOrFilter allItemsFilter = new LogicalOrFilter (conduitsandPipesFilter, ductInstancesFilter);
//put the items in a collector
FilteredElementCollector collector = new FilteredElementCollector(doc);
ICollection<ElementId> allIds = collector.WherePasses(allItemsFilter).ToElementIds();
//TaskDialog.Show("All Items size", allIds.Count.ToString());
//Go through each item in the lists
Transaction myTransaction = new Transaction(doc);
myTransaction.Start("Set Conduit Elevations");
foreach (ElementId id in allIds)
try
//Get the element from the id
Element e = doc.GetElement(id);
//Get the elements level
String ConduitElevationString = e.get_Parameter(BuiltInParameter.RBS_START_LEVEL_PARAM).AsValueString();
//Get the Project Parameter for the current element
Parameter ConduitElevationParam = e.LookupParameter("MyConduitElevation");
//if the elevation is vaild, then set the project parameter to the elements level;
if (ConduitElevationString != null)
ConduitElevationParam.Set(ConduitElevationString);
catch (Exception ex)
//something went wrong with an element - skip that element and continue
n=n+1;
}//end foreach
myTransaction.Commit();
if (n != 0)
string mymessage = "There were " + n.ToString () + " elements that could not have their elevation set.";
TaskDialog.Show("Revit Macro Message", mymessage);
}//end partial class
}//end namespace6. On the "Build Menu" (in the code window) select build solution. You will get a warning, but you should not get any errors. (Tested on revit 2018-2020)
7. Go back to the macro manager window, and highlight the "SetMEPElevationsMacro". The run button should be enabled. Press run, and you should get a message that X number of elevations could not be set. Press OK. Don't worry about the message box - that means the code is working and the hard part is done.
8. Now we have to make a project parameter. Again spelling and capitalization is critical. It has to be called MyConduitElevation to match the code. (If you want to change the name later, you can, but you have to change the macro code to match.)
8A. Select project parameters under the manage tab.
8B. Select "Add". Name the parameter as noted above. Select "Project Parameter", "Text" for the type, and select "Values can vary by group instance". In the Categories list, select "conduits", "ducts", and "pipes". (See the example window image I've attached.)
8C. Select OK.
9. Now you can add the "MyConduitElevation" parameter to your schedules. If you go to the edit fields, it will appear in the drop down list.
10. They will all be empty to start, but if you run the macro again, it should fill in all the elevations, and you shouldn't get a message box that says elevations couldn't be set.
If you change elevations, or add more items, you will have to re-run the macro. But that's pretty easy. On a file with 5000 items, it took about 30 seconds to run the first time, and it only took about 5 seconds to update a few changed elevations.
You will have to add the project parameter to every file you use this in, so you might want to add it in your template.
Let me know if this helps out.
