Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Shortcut to change selected Pipe/Duct/MEP Equipment phase created and demolished
TristanFCE
TristanFCE
I have search everywhere for an answer to my question.
Is there a way to make a shortcut to change selected Pipe/Duct/MEP Equipment phase created and demolished?
RobDraw
Are you looking for something shorter than the properties panel?
Rob
TristanFCE
Yes I was wanting to use a Keyboard shortcut. Like "DM" for phase Demolished. and "PC" for Phase Created. Maybe at the most just cycling through to existing or New construction with these shortcuts.
RobDraw
I'm having trouble thinking of any properties that can be set with the keyboard. If you could think of one, that might point you in the right direction.
Rob
TristanFCE
I guess I just thought that I would be able to have a keyboard shortcut set for phasing the same way the Visibility/Graphics override has "VG" But I suppose those are two different things.
Thanks for your responses.
