Serious Error has occurred
I'm getting a serious error has occured when trying to open a document. Below is a part of the journal file that has error in it but I can't figure out whats going on. We just started getting this with one model.
' 2:< API_ERROR { System.NullReferenceException exception(Object reference not set to an instance of an object.) was thrown from a handler of Autodesk.Revit.Proxy.DB.Events.DocumentOpenedEventArgsProxy event. The API event handler was registered by application CoordinationModelDB (c9463641-1c02-431c-9502-4ad0c91de1ce). Changes made by this handler are going to be discarded. }
' 2:< API_ERROR { System.NullReferenceException exception(Object reference not set to an instance of an object.) was thrown from a handler of Autodesk.Revit.Proxy.DB.Events.DocumentOpenedEventArgsProxy event. The API event handler was registered by application Export To Revit (df5b7489-f0e6-4f83-8010-3d852316d225). Changes made by this handler are going to be discarded. }
' 2:< API_ERROR { System.NullReferenceException exception(Object reference not set to an instance of an object.) was thrown from a handler of Autodesk.Revit.Proxy.DB.Events.DocumentOpenedEventArgsProxy event. The API event handler was registered by application Model Review Events (1469753f-186d-4dc2-b0e9-431b302e62f9). Changes made by this handler are going to be discarded. }
' 2:< API_ERROR { Autodesk.Revit.Exceptions.ArgumentException exception(The requested dockable pane has not been created yet.
'Parameter name: id) was thrown from a handler of Autodesk.Revit.Proxy.DB.Events.DocumentOpenedEventArgsProxy event. The API event handler was registered by application DynoApp (a7cc11aa-02eb-4a3a-9847-fc0183916b1d). Changes made by this handler are going to be discarded. }
'E 26-Feb-2019 16:12:38.246; 1:<
' 2:< CoordinationModel FileCache: cache location: C:\Users\cjr\AppData\Roaming\Autodesk\Revit\Autodesk Revit 2019\AddinsData\CoordinationModel\FileCache\zi3lqlxl
'Parameter name: id) was thrown from a handler of Autodesk.Revit.Proxy.DB.Events.DocumentClosingEventArgsProxy event. The API event handler was registered by application P&ID Modeler (502fe383-2648-4e98-adf8-5e604719dc34). Changes made by this handler are going to be discarded. }
