Revit MEP Forum
Selection cannot be copied
18 REPLIES 18
Message 1 of 19
Mustafa.Salaheldin
671 Views, 18 Replies
Hello
I have the shown MEP model:
When I select the model elements and press the copy button, I receive the error message shown.
The selected elements are:
But for some reason the copy fails, any ideas?
¯\_(ツ)_/¯
Let it work like a charm.
Mustafa Salaheldin
Digital Integration Manager, DuPod
Facebook | Twitter | LinkedIn
18 REPLIES 18
Message 2 of 19
This is the Revit build I'm using:
¯\_(ツ)_/¯
Mustafa Salaheldin
Message 3 of 19
Why would you copy all of that stuff in a 3D view?
Is this copy to clipboard to paste into a different project?
If this is copy within the project, try being strategic with your selection and do it in appropriate views.
Message 4 of 19
If you are in the mechanical discipline, generic models are tricky.
Message 5 of 19
Could you pls click expand button. Revit will show elements which cause the problem
Message 6 of 19
@RSomppi Essentially, I needed to develop an add-in that copies the elements from one file to another, then I hit this exception. When I decided to investigate the original file (the source file to copy) I discovered that in Revit project model, when I select the model elements and press the "Copy" button in the Revit UI I get this error message.
¯\_(ツ)_/¯
Mustafa Salaheldin
Message 7 of 19
@tawilson Please clarify more.
¯\_(ツ)_/¯
Mustafa Salaheldin
Message 8 of 19
@ducmap2212 The expanded message has no information.
¯\_(ツ)_/¯
Mustafa Salaheldin
Message 9 of 19
Hi. Seem like you are copying pinned element
Btw, Can you share this file so that I can make a test on it.
Message 10 of 19
@ducmap2212 I tried to unpin all pinned elements also but there was no change. Let me check if I can share the file as it is from a live project, so there may be some sharing restrictions.
¯\_(ツ)_/¯
Mustafa Salaheldin
Message 11 of 19
Have you tried limiting your selection in order to isolate the offending elements?
Message 12 of 19
I have seen elements and not be able to select them until I changed to the architectural disclipine. They were plumbing fittings that I believe were made with an addin. I work with an addin that creates generic model tags, and I can select them, but can't use the select all function. I don't know if changing the discipline changes that.
Message 13 of 19
@RSomppi Following your advice, I figured out that the Pipes are the reason.
When I removed them, the copy worked, if I select them only I receive the same error message, but no clue why this happens.
¯\_(ツ)_/¯
Mustafa Salaheldin
Message 14 of 19
I wouldn't have expected it to be the pipes. I copy/paste them from time to time.
Message 15 of 19
@tawilson With cherry picking, I found that a specific Pipe type is causing this issue:
If I excluded this type, copy works, so how can I know the reason?
¯\_(ツ)_/¯
Mustafa Salaheldin
Message 16 of 19
Trial and error?
Find differences from the other types. Adjust parameters accordingly and test again.
Message 17 of 19
sragan
in reply to: Mustafa.Salaheldin
I have no problem copying a vertical pipe in a 3D view in Revit 2022 (same version).
Did you try auditing the project?
Message 18 of 19
Mustafa, man!
It's probably hosted elements or the datum elements.
Can you copy one category at a time? for testing only?
Call me and let's do a zoom call!
Message 19 of 19
@Basam.Yousif OMG you are already level 10 😁 Couldn't see that coming my friend. Sure, it is my pleasure to investigate that together over a Zoom call.
With Level 10 you should be in the expert elite program already @Maureen.H would you please advise?
¯\_(ツ)_/¯
Mustafa Salaheldin
