Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Selecting insulation of ducts
3 REPLIES 3
marco.defina
4272 Views, 3 Replies
how can i select only insulation of ducts? I have only Insultaion in the view but i cannot select. So i cannot give comments or contruction stage at the insulation...
BIM Manager - HVAC and Plumbing designer https://www.autodesk.it/content/dam/autodesk/www/products/responsive-imagery/responsive-badges-compare/2019/navisworks-manage-2019-badge-75x75.pngApp AutoCAD per dispositivi mobili premiumNavisWorks Simulate3ds Max___________________________________________________________________________
Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums.
3 REPLIES 3
Hello @marco.defina,
Unfortunately, you can't select the Duct Insulation. It is part of the Duct or Duct Fittings.
If you give comments or construction stage to the Ducts you can create a Duct schedule with the insulation parameters Insulation Type and Insulation Thickness.
Then filter by comments or construction stage.
If you want to calculate the Insulation Area than just add a calculated value in your schedule.
Is this helping you?
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Robert Klempau
Senior Consultant AEC
Cadac Group AEC BV
Yes thanks!
Another way i tried is to modify the insulation of selected ducts and give the right construction stage...
This for me is important because can happens that the insultation will be posed in another construction from the ducts...
in reply to: marco.defina
I have experienced the same issue where I was unable to select just the duct insulation.
I have used Ideate Explorer which lets you easily select the insulation. Once I have them selected, I can make changes as I would normally do in Revit.
Here’s the screencast showcasing the process using Ideate Explorer:
Vasudha Dixit
MEP Application Specialist
