Hi All,
This is my first post here so hopefully I won't be mocked too much. Right here goes:
Although I am not new to using Revit my current company is having only done one project so far. I have two queries that I need advice on:
1: The company is trying to push the idea of using Revit to manually draft 2D electrical/mechanical/plant schematics. Other engineers at the company and I are opposed to this move as we feel auto CAD is much better suited to the task and we have it already set up for the job. Has any one got any views on this? Can Revit be used effectively to manually draft schematics or are we better off using AutoCAD?
2: If we persist in using Revit for drafting schematics what is the best way to create 2D schematic symbols? The way I have been instructed to do this is to create groups of annotative lines and use these as a "block". These are then further grouped to create a single system "blocks" that can be moved around and connected using lines to build a schematic. I don't think this is the most effective way of using Revit and see it becoming a problem in the future. Are there any better options or are my concerns misplaced?
Jake
