I use DiRoots to transfer most of my schedule from Excel to Revit. However, when I need to make edits to the Excel sheets, the views will disappear from the DiRoots UI, but still exist in the project. This will force me to import the schedules into DiRoots again, replace them on the sheets, etc. This can become a hassle if there are many schedules on a single project.
Has anyone else experienced this and/or found a solution?
List of schedules in DiRoots UI, missing ventilation schedules shown below
Solved by iainsavage. Go to Solution.
As far as I know there is no live link between the project schedules and the excel files so the process that you are describing sounds correct to me.
The team at DiRoots are however very responsive and competent and if you contact their support team you'll usually get a quick reply, usually on the same day.
Contact DiRoots Support:
support@diroots.com
Contact the DiRoots Support team:
support@diroots.com
