Schedule Default Parameters
I created a blank project.
I create a schedule, using Schedule/Quantities,Air Terminal category and it provides me a list of available fields  as shown in the attachment.
If I create a family using a Mechanical Family template and then change the Family  Category and Parameters to Air Terminal, many of the schedule fields are not included. I want to be able to use these parameters instead of adding Shared Parameters. I did check and make sure those parameters were not in that shared parameters file.
L.Maas
You mention "schedule fields are not included". Included where?
Some of the parameters will only become visible when the families are loaded into a project. The will be automatically added when loaded. So see what happens when yo load the family inside a project
Louis
Please mention Revit version, especially when uploading Revit files.
Thanks for the reply..I see what you mean.
