Revit MEP Forum
Sanitary Piping not showing up in HVAC
2 REPLIES 2
887 Views, 2 Replies
I have a water source heat pump family from McQuay and they have made the condensate pipe a Sanitary pipe.  Sanitary pipe will not show up in my view.
Is there some setting I am missing?
I have looked around a bit and cannot seem to find any setting specifically not showing Sanitary pipe.
I am using Revit MEP 2012 for the particular project.
2 REPLIES 2
Have you checked whether there are any filters which stop the piping showing up?
Also are there worksets in the project and are they set to show in the view?
Check bot of these using the Visibility Grpahics of the view
Smiley Frustrated Oh geez!  Duh.... Filters.  That was the problem.  I always forget Filters!  Thanks!
Forma Design Contest
