SAME SYSTEM NAME
SAME SYSTEM NAME
akash_aJUU6L
SAME SYSTEM NAME
akash_aJUU6L
Community Visitor
Community Visitor
RETURN AIR DUCT SYSTEM WHENEVER I DISCONNECT IT FROM MAIN DUCT THE SYSTEM NAME CHANGES. I WANT IT TO STAY IN THE SAME SYSTEM AS THE MAIN DUCT.
Radwan-Almsora
To keep your return air duct in the same system when disconnected, you must change your Revit system type properties to maintain the system name instead of letting Revit auto-generate a new one.When you disconnect a duct, Revit automatically assigns it to a new, default system because it loses its physical connection to the equipment or main run.
iainsavage
If you disconnect it then you will have created two separate systems so that's why the name changes. If you re-connect then it will re-adopt the system name.
If however, before you start placing ducts, you create a system and add the terminals to that system then the system name will be pre-selected and should be retained even if the ducts are not fully connected. You can also do that once you have already placed the ducts but you'll get a warning, which you can ignore, saying that the terminals are already in a system and will be removed from that system and moved to the other one.
iainsavage
PS: regarding the advice given by @Radwan-Almsora "you must change your Revit system type properties to maintain the system name instead of letting Revit auto-generate a new one", I know of way of doing that by changing type properties.
The only way that I know of is as I describe in my previous answer.
