Room tags linked different name
igoteseanu6NLUR
igoteseanu6NLUR
Good morning,
I have a qustion about the room tags from linked model which I want to see in my project.
I try to copy the room tags from linked model but I get a different name than the original project.
Apparently my project shows the Rooms>Number and not the Room tags according to the original project.
How can this be resolved?
Thank you in advance !!!
Room tags original projectRoom tags original projectRoom tags my modelRoom tags my modelTags original projectTags original project
iainsavage
Select all tags using right click > select all in project, then change the tag type in the property browser
igoteseanu6NLUR
I changed the type tag but it doesn't work
fabiosato
They are in the same Phase?
Fábio Sato
igoteseanu6NLUR
Hello Fabiasato,
They are in the same Phase.
I see that in the original model is also Rooms and Roomtags separate.
igoteseanu6NLUR
It's solved 🙂
It just saved the family ( Room tag) from the original model and opnened in my project.
Thank you for your help !
iainsavage
You need to check which parameters are labelled inside this tag family:
Maybe it doesn't have the room name parameter included in the labels?
When you said that you had copied the tag from the architecture model I thought you were going to be using that tag in your own model which is why I said to select all tags then change the tag type from your own family to the copied family.
Or edit your own tag family and make sure it has the correct parameters labelled.
