RevitWorker.exe
RevitWorker.exe
mitch.condie
Message 1 of 9
RevitWorker.exe
mitch.condie
What exactly is RevitWorker.exe?  Why does it start randomly? and why does it kill my machine performance?  Can it be turned off?
Replies (8)
Message 2 of 9
eric_grey
RevitWorker is a secondary process that has been added to Revit.  We are moving various features to this process.  Color fills and volume calculations are examples of features that have been moved so far.  This allows modifications to process in the background while the user continues to work.
Can you give more detail on when you are seeing this kill your machine performance?
Eric
Eric Grey
Software QA Analyst
Message 3 of 9
dzanta
Export to DWF/DWFx: To significantly reduce processing time when exporting views/sheets to multiple DWF or DWFx files, the software now uses several RevitWorker processes. For export to DWF or DWFx, you can select one or more views and sheets. When you export multiple views/sheets to multiple output files, the software uses additional worker processes to perform the export work using multiple threads. As a result, the DWF export operation finishes more quickly. (The Revit software is unavailable to perform other work until the export operation completes.)
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Message 4 of 9
mitch.condie
I wish I could give more details. It happens 3-4 times a week. I am usually in Revit 7-9 hours a day.  My machine will randomly lock up.  I will look at all processes running and see RevitWorker.exe. As soon as I kill that process, my machine will instantly run awesome again. We have noticed this on about 10-15 machines in the office. I have tried to pinpoint and compare machine specifics (OS, hardware, etc.).  I have not found anything consistant.  Most machines are running Windows 7 or 8.  I will get more feedback from other users in the office and add details when I hear back.  We do switch volume calculations to area only as a standard.  Then when we do need them we switch it back.
Message 5 of 9
mitch.condie
Thanks dzanta, I have seen that.  This usually happens not during an export or print.
Thanks for the response!
Message 6 of 9
dzanta
I would contact Autodesk Tech support for this one....
Message 7 of 9
Hi: Would mind explain to me how to do that "We do switch volume calculations to area only as a standard.  Then when we do need them we switch it back. "
Message 8 of 9
krrp
The revit worker black screen just started showing on my machine. It appears now when trying to open a revit file by double clicking on the file name. Both project files and family files will invoke the terminal screen. Two warning boxes will appear noting "the parameter is incorrect" then revitworker crashes.
This never appeared before and I have never had problems double clicking and opening a revit file before.
I am guessing an update is causing this. I am still on the 2019 version, but will update to 2020 and see if the problem goes away.
I can still open files the old fashion way by using the open files commands inside revit.
Mac-Pro late 2013, 3.5 GHz 6-Core Intel Xeon E5, 32 GB 1867 MHz DDR3 ECC, Two AMD FirePro D500 3072 MB,
Donated 147GB of hard-drive space to Virtual Machine running windoze 7, Autocad 2019, Revit 2019 Eagle Point, & Sokkia surveying software
Donated 10CPUs & 42GB of memory to Virtual Machine. Pegged virtual machine video memory at 2GB
Parallels Desktop for Mac - Version 14.1.2 (45479)
Mac OS X 10.14.5 (18F132)
Message 9 of 9
adrian.betana
Why revitworker is in detailed steel modeling background process. It said "Restart or report bug if available" When will be it available? It is killing my time FYI AUTODESK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
