Revit View Template
Revit View Template
YImamY859U
Revit View Template
YImamY859U
what steps should we take in Revit to remove or delete all view templates at once? I have lot of unnecessary templates that i need to remove all at once.
edwin.prakoso
You can use the Dynamo Graph attached to this post. You need to unzip it first, as I can't upload the original file directly due to the forum's security.
Read on how to configure Dynamo Player to run the graph here: https://www.cad-notes.com/how-to-use-dynamo-graph-in-dynamo-player/
Then, you can click run to remove ALL view templates in the active project.
Cheers,
Edwin Prakoso
