Revit to IFC export
Revit to IFC export
vick1z
Revit to IFC export
vick1z
Dear Autodesk Community,
Please find attached screenshot, my fittings aren't coming correctly in IFC export, is there any setting I need to change while exporting to ifc or can geometry gym external plugin could help resolve this issue?
Look forward to hear from you.
Dale_Golden
What version are you using?
Is this a problem in other projects/versions?
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Certain-Structural...
Dale_Golden
fabiosato
You can change the level of detail.
But be aware that the conversion time e IFC file size can increase a lot.
Fábio Sato
vick1z
@fabiosato Thanks for your reply, changing the detail level to high gives correct geometry but it does not come with proper material / texture Revit to IFC_1.PNGsee attached screenshot. is there any way to get it right ?
fabiosato
You can assign the material through a material parameter linked to the geometry within the family editor.
Fábio Sato
