Revit Task Automation For MEP Model Preparation & Export
henry_eduvie4GZRT
henry_eduvie4GZRT
I am currently using version 2022 and I need to issue MEP models on a bi-weekely basis to my client. I must implement the following tasks before every issue:
  • Delete all views except the default splash/home view
  • Delete all sheets except the splash sheet
  • Purge all unused families
  • Compact the project file if possible
  • Export the model to IFC 4 format
  • Export the model to Navisworks NWC format
Can anyone suggest how i can automate these tasks
I look forward to hearing from you all
Thanks, in anticpation
Regards
fabiosato
You can use e-Transmit to delete views, sheets and make the purge, I suggest you to leave a 3D view to Export to Navisworks and IFC
Fábio Sato
