REVIT SWEEP CREATION ISSUE
Ajay_J_S
Message 1 of 15
Ajay_J_S
HI I AM TRYING TO CREATE A SWEEP OR SWEPT BLEND FOR THE PATH AS SHOWN IN THE PICTURE BELOW
THE PATH RADIUS IS 12.5 & AT AN ANGLE OF 45 DEGREE. I SKETCHED A PROFILE WITH SAME RADIUS 12.5 AS I REQUIRE AT THAT SAME RAIUS OF PATH I AM GETTING ERROR & UNABLE TO CREATE A SWEEP. TRIED USING BOTH SWEEP & SWEPT BLEND GETS THE SAME ERROR
APPRECIATE IF SOMEONE HELPS & PROVIDES A SOLUTION
Replies (14)
Message 2 of 15
iainsavage
I'm pretty sure that it can't create the sweep because it can't form a radius at the throat.
I changed the profile radius to 12.4 and it will work then.
Message 3 of 15
Ajay_J_S
IF REDUCING RADIUS WOULD WORK, THEN THE ELEMENT I USE IN PROJECT WOULB BE INACCURATE... HELP ME WITH WORKAROUND
Message 4 of 15
Ajay_J_S
REVITFAILS WITH ACCURACY & PRECISION FOR MODELING THE PROJECT & IN CREATION OF FAMILIES.
Message 5 of 15
RobDraw
That's a pretty big jump based on not being able to make something that has been made many times by others.
Rob
Message 6 of 15
Ajay_J_S
ya stupid software stupid autodesk never looking at accuracy & precision
Message 7 of 15
iainsavage
Its not stupid software, its geometry.
You are trying to create a radius on the throat, but there can't be a radius because of the values being used.
How about 12.499999? would that small "error" be acceptable?
Message 8 of 15
Ajay_J_S
I dont want to create something with error since values would populate from size lookup i am unable to use those error values. Anyway thanks for reply
Message 9 of 15
RobDraw
You are trying to create a shape that is impossible and you are blaming the program.
Brilliant!!!
Rob
Message 10 of 15
iainsavage
Use a formula, deduct 0.000001 from the lookup table value.
Or do it a different way other than using one sweep.
Message 11 of 15
iainsavage
This one (Wavin Osma) uses two extrusions and a revolve to get a radius on the heel but a mitre on the throat.
Message 12 of 15
Like these?
Message 13 of 15
Ajay_J_S
How u=you created this with sharp turn on the inner radius??
Message 14 of 15
Mahmoud.Ziedan
@Ajay_J_S
this can be done by revolve not sweep.and in revolve change the angle
You found a post helpful? Feel free to give it a like!
Your question got successfully answered? Click the 'Mark as Solution' button.
Mahmoud Zeidan
BIM Manager / Mechanical Engineer
Message 15 of 15
I used revolve, as the screenshot shows.
