Revit MEP Forum
Revit Section Multirouting Glitch?
1 REPLY 1
joseph_mason
269 Views, 1 Reply
joseph_mason
Observer
Observer
Hi, I'm trying to draw a fab duct in a section view. When i multiroute from the fabrication duct node revit trys to offset the duct to the side and force in a angled fitting. It only does this when the section is vertical within a plan view, if i rotate it 90*, it works fine. I've tried all far clip options, checked height is correct and i can't see any reason why it would do this. I've spoken to a another user who says it a glitch that he's experienced before on a previous edition, has anyone experienced this and found a method to fix / workaround it?
I've attached an image showing what happens.
1 REPLY 1
Rafal.Gaweda
in reply to: joseph_mason
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @joseph_mason
Could You be so kind and record and post video with Your steps.
You may use https://knowledge.autodesk.com/community/screencast to do this.
Thank You for cooperation.
Rafal Gaweda
Hi @joseph_mason
Rafal Gaweda
