Announcements
Revit Roombook "top rail"
MichaelSpahn
Advisor Advisor
MichaelSpahn
Hello Community,
i would like to create an equipment list in Revit with the Roombook. When exporting to Excel, the family is always preceded by "upper railing" German: "oberer Geländerholm".
Is there a solution for this, how I can remove this indication?
Only the family name is sufficient for me here.
thx, Michael.
Stay hungry, stay foolish!
Viele Grüße,
Michael Spahn
TGA Planer/Konstrukteur
Firmenwebsite | LinkedIn
Ihr fandet einen Beitrag hilfreich? Dann vergebt dafür doch Likes!
Eure Frage wurde erfolgreich gelöst? Dann einfach auf den 'Als Lösung akzeptieren'-Button klicken!
iainsavage
I'm guessing this is hanger assembly, Unistrut or similar?
"Upper railing rail6: _E_CAX RE-Parapet channel_P1_P2: Center edge"
I don't have Roombook installed any more so can't remember the syntax but I assume that information comes from the family so you maybe need to edit the family?
An alternative quick solution would be to edit it in Excel after export using Find & Replace in Excel.
