Revit Printing Filled Regions Not Aligned to Sheet Properly
pcanonWZ2DB
pcanonWZ2DB
Users with Revit LT 2025 & Revit 2025 within the office have issues with printing.
First couple of pages are typically not printing correctly (first ~8-9 pages).
Affected sheets containing filled regions (from legends/plan views/and the sheet title block) will not print properly, being offset diagonally by a couple of inches from the origin point, when using 'Print' command.
Printing using Rasterized quality also yields the same issues.
Issue also only arises when using Arch D sheet size.
However, 'Exporting' a PDF does not contain this issue.
Issue started to occur midway throughout the day (no updates prior, printing previously worked normally)
Note: I only have printed using Bluebeam as I do not have admin privileges to download a new PDF viewer.
iainsavage
Likely to be a bluebeam issue, there have been similar posts in the past.
pcanonWZ2DB
I thought that might be the case as well as that's the only variable I haven't been able to try. I'm currently awaiting IT support. Will update post if anything comes of it.
