Revit MEP Flanges / Welded pipes
![](/skins/images/BDA404F3EDE66A862CFF9F8AD40C6D90/responsive_peak/images/icon_anonymous_message.png)
- Mute
- Permalink
- Report
I'm having problems using flanges and welded pipework in the same system using Revit Systems (MEP).
You can set the flange you'd like to use in routing preferences and this works if you only use flanged fittings and accessories. If you want a welded connection you can remove the flange from routing preferences, but this will also remove flanges connected to flanged fittings / accessories if you do anything to that particular section of pipe.
I've tried different different pipe types for flanged / welded pipe but this still doesn't get around the problem when you have flanged one end / welded opposite end pipework.
The only workarounds involve manually inserting flanges between welded pipes and fittings, but this causes problems for me with hidden / cut lines in views using mechanical discipline.
Has anyone ever managed a proper solution to this or will the problem remain until Revit fades away?
James
