REVIT MEP 2019 | ATTEMPTING TO INSERT A MITSUBISHI CASSETTE FAN-COIL PLFY-P32-40-50-63-80-100-125VBM-E
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I use AutoCAD MEP successfully, and I have used AutoCAD since 1996, so I am likely to have an AutoCAD head on when using terms.
I live in the U.K. and I am fairly new to Revit MEP I am trying to insert a Mitsubishi cassette fan-coil PLFY-P32-40-50-63-80-100-125VBM-E into the ceiling grid — 600mm × 600mm at the offset of 2,700mm — but without success.
Having loaded the family into the project, I click on the “Systems” tab › “Mechanical” panel › “Mechanical Equipment” button, go into the “Properties” dialogue box and select the cassette fan-coil size that I want, PFLY-32VBM-E_240V_50Hz and the “Modify | place Mechanical Equipment” contextual tab comes up.
I am now ready to locate the cassette fan-coil into the ceiling grid, but it shows me the no go sign 🚫.
I have tried to insert it in ceiling plan view, elevation view, and 3D view, but all show that same sign.
Can someone help please? Many thanks in advance.
Tim.
