Hi Guys,
I just wanted to know if the below-mentioned case is possible:
When I give the pdf print from Revit I can see the line weights in pdf and I can also toggle the settings if I need to see the thin lines in the same pdf, but when we plot it on paper, it shows thick lines. Is there a method to plot the sheet with thin lines only without changing the actual line weight settings in Revit.
Thank you in advance!
No. Nothing I can add to that really 🙂
A similar question and answers that may help you.
