REVIT LIGHTING
REVIT LIGHTING
marbess
REVIT LIGHTING
marbess
Hi All, im fairly new to Revit, coming from the lighting design field and AGI32. i built out a residence for a lighting project and pulled in some adjustable downlights for use on the 2"/12" sloped ceiling. the issue is the angle of the light beam follows the slope of the ceiling, instead of pointing directly down. is there a way to aim just the light source and move the beam? thanks
L.Maas
You should modify the lighting family or create a new one. You can modify/create a family in such a way that you can rotate forms or nested families. If needed on all 3 axis.
Search the forums or the internet on  how to do this.
Louis
Please mention Revit version, especially when uploading Revit files.
curtisridenour
There is an angle parameter for the light source. This is available if you have a photometric web file light source (IES file). To utilize this parameter you might need to ensure the light is rotated the exact right direction.
