Revit family with Index formula
jan.appelgryn
jan.appelgryn
Good afternoon,
I have this formula in Excel that look and compare two columns and give the values of the 3rd and 4th columns if both are true, I want to use this in a RVT family, can anyone help please. Below is the table that will run from a csv lookup file.
=INDEX($C$3:$C$895;MATCH(H4&" "&I4;$A$3:$A$895&" "&$B$3:$B$895;0))
The formula must resolve when ND_Main (column A) and ND_Red (Column B) is in the same row (Row 5) in the csv file and then return the values that is in Column C (for the value in Column A) and Column D (for the value in Column B)
See the atachment
Thanks in advance
Jan
timlove
A lookup table does not work with a formula like that.
https://help.autodesk.com/view/RVT/2022/ENU/?guid=GUID-91270AEF-225A-49D7-BF84-1F44D1E3E216
result=size_lookup(LookupTableName, LookupColumn, DefaultIfNotFound, LookupValue1, LookupValue2, ..., LookupValueN)
So if you wanted to get the value in ColumnC, when A and B have a set value:
result=size_lookup("MyTableName", "ColumnCName", "Did not find matching data", ParameterToMatchColumnA, ParameterToMatchColumnB)
Repeat to get your value for D.
Typically I will create a formula instead of reporting an unusable value, but it depends on what data you are retrieving.
jan.appelgryn
Hi, thanks for this, but it seems that my formula skill need some upgrade, I did not used this, I created a simpler version where I have if statement to the value if needed can be filled in. Thanks for your advice.
Kind regards
Jan
