Revit Family Select New Face Not Working
bgumPXZJF
bgumPXZJF
I am using Schneider Electric's "Layout Fast" add on for Revit. You select the electrical panel you want and it insert it on plan like a native Revit MEP electrical panel.
It appears as though the family is setup from a view that it should not be. Please see screen shots below. When I try to place the existing panel on a new wall using the "Pick New [Face]" command it displays the panel in the completely wrong orientation.
How do I correct this in the family definition? Help me understand what the cause of this issue is and If I can fix this. Typically I place my panels from a top-down floor-plan view. But the way these are setup you can only place them in a 3D view if you have a good angle facing the wall.
I realize these questions are broad. Please help me understand.
I am attaching the Revit family below.
cant rotatecant rotate"select new [face]" comes in at wrong orientation"select new [face]" comes in at wrong orientationTrying to place panel on new wallTrying to place panel on new wall
RobDraw
You should probably be asking the source of the add-on for the proper way to use it first. The family may be designed that way purposely.
Rob
s.borello
I'm not familiar with this add-on but I'm curious if hitting the space bar after you select new host does anything to the panel; similarly to a native RVT family?
I tested your family in RVT 2021 and it works as expected; I did need to hit vertical face to get it to host in a plan view, spacebar will rotate as expected.  In a 3D view, place on face works.
bgumPXZJF
That's interesting. Thank you for trying in 2021. Wonder what the issue is then. - Yes space bar just rotates but again is at the wrong orientation.
aeidAEEEF
Try one of these two ways:
Go to edit family and then to upper left corner ''family category and parameters'' the parameter ''always vertical'' should be inactive  and then save changes and load the family again in the model.
If that didn't work then try to place your component on a seperate ''reference plane'' then you have the ability to rotate your new ref.plane as you want
If this helped please mark it as a solution.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
