Revit Fabrication Sloped Pipe Multi-Point Routing
06:07 PM
I have been drawing in sloped pipe in Revit Fabrication 2020 and whenever I use the Multi-Point Routing tool or try to connect to ends with the "Route and Fill" commands, I get an error that says: "Fabrication fitting could not be made to fit. Unable to change fabrication dimension." I have adjusted the tolerance angle for the fittings to 3, tried utilizing different pipes, but I have run out of solutions. Thanks, Aaron
