07:04 AM
Somewhat new to customization in REVIT and I'm looking to create a family Diffuser Tag that in the drawing I can specify the size and it will adjust the block equal right and left (centered), similar to how a dynamic block behaves in ACAD. Currently if I adjust the length in the working environment it adjusts the block to the right only and doesn't keep the text centered (stays aligned to the left). I don't see an option to correct this. Thanks!
Image is attached of current family block and what happens when size is adjusted.
