Revit Cloud Model- Batch Print
dipen609
dipen609
I have Revit Cloud model. When I tried to print batch plot, it says "Batch print does not support cloud model. Please save it in local model and run batch print again"(refer  attachment 1).  And from local file I have to arrange/sort sheet every time I made local file (refer  attachment 2).
What is the best way to print from cloud model when you have more than 100 sheets. Please note that I am using Bluebeam 2022 for printing and Revit 2022 for modeling.
Thank you,
Can you use Revit 2022 native Export to PDF?
dipen609
Yes, I have issue with sorting. I can not move the sheets up or down, please refer the sheet requirement. My sheet numbering is different and it is sorted by sheet number. I can not change the sheet number due to project requirement.
dipen609
Refer the attachment
3.
Open the model detached and batch print from it.
dipen609
There is no difference. I can not move the sheets up or down. And I do not want save file locally and arrange the sheet every time.
