Revit 2024 Plumbing Equipment Family
JKRevit
JKRevit
I built a Plumbing Equipment family for an Oil/Sand Interceptor. The interceptor is installed below a finished floor with a round access cover. With a Hidden Line Visual Style applied to a Plan View I expect to only see the cover, not the geometry of the Interceptor below the Floor slab. All of the geometry of the Interceptor is visible. How can I adjust Visibility so only the round cover shows in a Plan View. The bottom of the View Range of the Plan View is at the same elevation as the access cover.
fabiosato
You can change the visibility of the parts, unchecking plan view visibility
Fábio Sato
JKRevit
Fabio;
Your suggestion worked perfectly. I turned off Plan View Visibility for all family geometry below the floor slab. Another positive of this suggestion is that Section and 3D Views are not affected by this Visibility Setting change. Thanks for your quick response.
