Revit 2024.2 New Home Page and ACC Issue
robertas_suminskas2
Message 1 of 8
robertas_suminskas2
I noticed that the Revit New Home page doesn't work well as it should work with AutoCAD.
The support team made a clean unistall of Revit and Install from the beginning. The problem still the same. Also support team reset the Desktop Connector as well and it reinstalled as well. Also same problem on a remote PC. It should be similar results as it shows on AutoCAD. The team need to look at this. I do love Idea with new features but it must work.
Does someone have the same problem? Or have any ideas how to solve it
Replies (7)
Message 2 of 8
nmarcelis
Use the old Revit home?
I always wait long enough to try new features, for not having to worry on bugs.
Revit Certified Professional Architecture, Structure and MEP.
Message 3 of 8
HVAC-Novice
What is he "new home" feature supposed to do? What is wrong with how it works?
"Doesn't work well"  isn't too clear. What exactly is wrong?
And you host the Revit file in ACC "files"? Or is that some BIM 360 thing? Does it work if you have the file on regular network drive?
All this ACC stuff is a bit rough around the edges. Considering the pace Autodesk improves Revit, ACC will be usable in about 20 years.
Revit Version: R2026.5
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
Message 4 of 8
robertas_suminskas2
With the old version Revit Home you can't Pin Projects.
When it comes to ACC, with older Revit Home Screen you see all projects in ACC there with new one you see only that you selected in the Desktop Connector setting.
For me, it is a big difference when you have a lot projects.
Message 5 of 8
Can you explain what is not working? I just update from 2022 to 2024 for a
month and can't see any differences between the two home pages.
Message 6 of 8
robertas_suminskas2
In order to activate the New Home feature you need to toggle the button where the red arrow is showing.
Message 7 of 8
kris_berg
It looks like you are accessing different accounts/hubs in AutoCAD verses Revit.  I have outlined the account name in green in the attached image.
Kris Berg
Senior Software Architect - Autodesk
Message 8 of 8
RSXPR
Observer
Observer
Another issue with New Revit Home. I can't find a way to switch to the US server. It only shows the EU server. I don't have an issue with the old Revit home.
I have shared projects from the US server, and I can't use them with New Revit Home.
