Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
So the new version has added the ability of demolished MEP elements to maintain their categories in response to multiple request on the ideas forum. Works great except for one major issue. To keep the system type the developers also physically are keeping the demolished element connected even when not visible.
The example I ran into was a project where I need to demolish all ductwork downstream of an existing terminal unit to allow for new ductwork to be installed in a new phase. Downstream ductwork was set to be demoshed in the new construction phase and that worked well. The problem is that when I went to connect the new ductwork to the terminal unit you cannot connect it as the demolished ductwork is still connected in the Revit DB. This is a major issue as we do work on existing facilities all the time and up until now this was not an issue.
Obviously, you need top disconnect the demolished duct in order to connect new duct to the existing to remain. The demolished duct doesn't need to be connected. The old demolish behavior disconnected everything. It's the lesser of two evils. If you don't like it, you could chalk it up to "be careful what you wish for..."
I think I would rather push to get Autodesk to get the functionality correct versus accepting another 10 years of work arounds. This issue will present far more challenges than what was happening before. I rarely had to back up and un-demolish a system to a point where having it still connected would be a benefit. I routinely break into existing piping and ductwork systems to connect new sections or equipment.
Yes, not actually connecting the to be demolished ductwork is a solution but it is a bad one and continues the past habits of just working around things than actually trying to make them work.
IMVHO, the previous functionality worked and made sense but opinions don't get heard here. Go to Product Feedback or the IDEAS forum and remember that your opinion on what is right can be quite different from others.
@moodyj2000 wrote:This issue will present far more challenges than what was happening before. I rarely had to back up and un-demolish a system to a point where having it still connected would be a benefit.
Totally agree. I would have left it the way that it used to work.
Most of my projects involve some element of refurb and we are routinely connecting new parts to existing systems.
So do we now have to manually disconnect demolished items in order to connect new to old?
How I can connect to the coupler connector to which the pipe was connected before, but it has been demolished. Is it possible in version 2023, there was no problem with it before. As I read what you write, I recognize that now I have to disconnect every branch that is demolished, this is ridiculous.
@moodyj2000 wrote:
draw the new ductwork right up to the existing coupler, and live with the sad looking graphics when two things touch but are not connected. Definitely frustrating.
This sounds like the way it used to work with everything getting disconnected. What were you doing before?
The problem with that is that there is no system connectivity, its only a graphical solution.
With the old method undemolished parts of existing systems could be reconnected to new systems and the whole system would function correctly.
They’ve changed the method because people wanted demolished parts (scrap metal) to retain system data and now it seems that you can no longer connect retained existing parts back into new systems (which happens on about 75% of my projects) so I’m going to have to play about with this and figure out some sort of workaround.
@moodyj2000 wrote:
This eliminates any possibility of actually using the capabilities of Revit for calculations, sizing, etc..
Eliminates? Are you sure it's not just a matter of finding a different workflow?
@moodyj2000 wrote:
They cannot be connected because the change in how the developers chose to handle demolished components does not allow for future connections.
Then why demolish it in the first place?
Why are you demolishing ductwork that you plan on reusing?
That's a pretty long winded way of saying what's already been said. The problem with your previous comments was too many words that made it sound like you wanted to reuse the demo duct. Yes, the new functionality of the demolition tool does require you to disconnect. The old way disconnected everything and removed system information. I didn't use the old demolition tool and opted for making a demolition phase which required disconnecting from the existing to remain.
So, it seems Autodesk has determined that this is what the users want which is sometimes a problem with satisfying the complainers that can't see the bigger picture. The silent majority loses.
As to your comment about losing the ability to use calculations, you couldn't be more wrong. The functionality is still there if you use a proper workflow. Just because disconnecting is beneath you, doesn't mean the functionality has been eliminated.
@RobDraw could you describe the workflow for the benefit of others? To disconnect do you have to grab the ends of the ducts, pull them apart and then use the Divide System tool? Or do you use the Split tool then delete the union and then divide system? What’s the best way to do it?
I’m genuinely interested in a constructive answer to this problem and hoping that this thread doesn’t end up like some of the previous ones on the topic of demolition.
