Revit 2020 Family Model Lines/Symbolic Lines do not show in Plan View
_mames
_mames
I use the out-of-the-box P-Trap family. When I used this Family in 2018 Revit, I modified the annotation lines of the family to be on a Subcategory so that I may toggle the visibility of said lines in other views. I just recently started using 2020 Revit and realized the lines do not show in Plan View. I did extensive testing and deduced that something changed in the way Model/Symbolic Lines behave in Plan from 2018 to 2020.
I challenge anyone else to test this. Take a Fitting in 2018 plan view, Edit Family, put all Model/Symbolic Lines on a new Subcategory and load into project. It will show fine. Now do the exact same procedure in Revit 2020 and the lines will disappear in plan view. It's almost if Revit now does not like lines within a family to be on their own Subcategory.
Why did this change? It is frustrating because this family worked fine in 2018 and now does not work in 2020 and I do not see any work around. I need the lines in this Family to not be under the veil of the Pipe Fittings Subcategory. I need them to be on their own Subcategory to toggle their own respective visibility and not turn off all Pipe Fittings.
Edit: It seems that the lines show fine in Plan if the fitting is parallel to the Plan but if the fitting is rotated so that it is perpendicular to the Plan (as P-Traps are) the lines disappear. Doesn't make sense.
Secttor
Are you sure there's nothing related to that view setup?
Revit MEP - Electrical Certified Professional
Revit MEP - Mechanical Certified Professional
Draftworks.wordpress.com
_mames
Positive. I had also started from blank templates in 2018 and 2020 to test it and what I found seems accurate. It looks like there is a super delicate balance between "Use Annotation Scale", the orientation of the native plane of the family (perpendicular vs parallel to the view), Model vs Symbolic lines, and if those lines are on a Subcategory or not. If you alter a family with different variations of those 4 items you achieve different results in the view.
I've attached my findings. Also lets say you have two instances of perpendicular and parallel lines in a family. If Revit deems it not visible (per my chart) it will not show any lines regardless of orientation.
The family I tested was the Generic Elbow
