Revit 2017 MEP Fabrication Ductwork VG Filter
Hi
I'm trying to apply visibility filters to MEP Fabrication Ductwork parts in Plans, Sections & 3D. has anybody had success with applying filters to these parts?
Regards
Russell
nathan.chapman
Are you trying to apply a fill pattern?  If this is the case,  this functionality doesn't currently work.  Its very deceiving in that you can assign a pattern to a a filter but if you go the the views VV setting you will notice that the pattern is grayed out.   If this is not the case what are you trying to do.  We don't have issues other than the pattern.
Nathan Chapman
Production Manager at General Heating and Air Conditioning
Revit Architecture Certified Professional
Revit MEP Mechanical Certified Professional
Revit MEP Electrical Certified Professional
DynaFabrication Package Author
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDOS button.
